Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
If your Huawei SnapTo G-620 won't turn on, then the motherboard may need to be replaced. This guide shows you how to replace the motherboard in your SnapTo.
  1. Pry open the back cover with your fingernail, using the divot to the lower left hand corner. Remove all fifteen 4mm Phillips J00 screws on the back panel. Using a metal spudger or your fingernail, remove the back panel.
    • Pry open the back cover with your fingernail, using the divot to the lower left hand corner.
    • Remove all fifteen 4mm Phillips J00 screws on the back panel.
    • Using a metal spudger or your fingernail, remove the back panel.
  2. Remove the pictured 4mm Phillips J00 screw.
    • Remove the pictured 4mm Phillips J00 screw.
  3. Use a plastic opening tool to remove the pictured flat-top connector. Use a plastic opening tool to remove the pictured flat-top connector.
    • Use a plastic opening tool to remove the pictured flat-top connector.
  4. Remove the battery.
    • Remove the battery.
  5. Use a plastic opening tool to remove the pictured flat-top connector. Using the plastic opening tool remove the camera.
    • Using the plastic opening tool remove the camera.
  6. Use the plastic opening tools to remove all the remaining flat-top connectors Use the plastic opening tools to remove all the remaining flat-top connectors Use the plastic opening tools to remove all the remaining flat-top connectors
    • Use the plastic opening tools to remove all the remaining flat-top connectors
  7. Using the spudger, pry open the zif connector, and remove the cable. Using the spudger, pry open the zif connector, and remove the cable. Using the spudger, pry open the zif connector, and remove the cable.
    • Using the spudger, pry open the zif connector, and remove the cable.
  8. Using flat-side of spudger, remove the motherboard.
    • Using flat-side of spudger, remove the motherboard.
Abschluss
Brian Omer Uzan
401 Reputation
4 Anleitungen geschrieben
USF Tampa, Team S2-G6, Nance Fall 2017 Mitglied von USF Tampa, Team S2-G6, Nance Fall 2017
USFT-NANCE-F17S2G6
4 Mitglieder
5 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 2
Insgesamt: 237
