Einleitung
Use this guide if your Huawei Union’s camera is not working properly, photos are obstructed or unclear.
Was du brauchst
Wedge your thumb nail, or the flat end of a spudger, into the bottom left corner and pry off.
Use the flat end of a spudger, or fingernail, to lift up the battery and pull out.
Remove the thirteen 3mm Phillips #00 screws from the back panel.
Abschluss
