Zum Hauptinhalt wechseln
Einleitung
Use this guide if the Huawei Union’s camera will not work properly.
  1. Wedge your thumb nail, or the flat end of a spudger, into the bottom left corner and pry off. Wedge your thumb nail, or the flat end of a spudger, into the bottom left corner and pry off.
    • Wedge your thumb nail, or the flat end of a spudger, into the bottom left corner and pry off.
  2. Use the flat end of a spudger, or fingernail, to lift up the battery and pull out. Use the flat end of a spudger, or fingernail, to lift up the battery and pull out.
    • Use the flat end of a spudger, or fingernail, to lift up the battery and pull out.
  3. iPhone Akku Fix Kits
    Nur $29.99
    Buy Now
    Nur $29.99
    Buy Now
  4. Remove the thirteen 3mm Phillips #00 screws from the back panel.
    • Remove the thirteen 3mm Phillips #00 screws from the back panel.
  5. Use the flat end of a spudger to pry off the back panel.
    • Use the flat end of a spudger to pry off the back panel.
  6. Use the flat end of a spudger to disconnect the camera from the motherboard. Pull the camera out to remove.
    • Use the flat end of a spudger to disconnect the camera from the motherboard.
    • Pull the camera out to remove.
Abschluss
Brittany Achor
705 Reputation
6 Anleitungen geschrieben
USF Tampa, Team S1-G1, Nance Spring 2018 Mitglied von USF Tampa, Team S1-G1, Nance Spring 2018
USFT-NANCE-S18S1G1
4 Mitglieder
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 64
