Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
Use this guide if your Huawei Union will not charge when plugged into a charger or begins losing charge faster than previously observed.
  1. Wedge your thumb nail, or the flat end of a spudger, into the bottom left corner and pry off. Wedge your thumb nail, or the flat end of a spudger, into the bottom left corner and pry off.
    • Wedge your thumb nail, or the flat end of a spudger, into the bottom left corner and pry off.
  2. Use the flat end of a spudger, or fingernail, to lift up the battery and pull out. Use the flat end of a spudger, or fingernail, to lift up the battery and pull out.
    • Use the flat end of a spudger, or fingernail, to lift up the battery and pull out.
  3. Remove the thirteen 3mm Phillips #00 screws from the back panel.
    • Remove the thirteen 3mm Phillips #00 screws from the back panel.
  4. SPAR DIR DAS UPGRADE
    Mach dein iPhone so gut wie neu mit unseren Fix Kits.
    Jetzt entdecken
    Jetzt entdecken
  5. Use the flat end of a spudger to pry off the back panel.
    • Use the flat end of a spudger to pry off the back panel.
  6. Remove a single 3mm Phillips #00 screw  from the motherboard.
    • Remove a single 3mm Phillips #00 screw from the motherboard.
  7. Using the flat end of a spudger to disconnect the motherboard ribbon cable. Using the flat end of a spudger to disconnect the motherboard ribbon cable.
    • Using the flat end of a spudger to disconnect the motherboard ribbon cable.
  8. Firmly hold the second ribbon cable's plastic film cover and pull up to disconnect.
    • Firmly hold the second ribbon cable's plastic film cover and pull up to disconnect.
  9. Wedge the flat end of a spudger underneath the motherboard and pry upwards to separate it from the frame. Wedge the flat end of a spudger underneath the motherboard and pry upwards to separate it from the frame.
    • Wedge the flat end of a spudger underneath the motherboard and pry upwards to separate it from the frame.
Abschluss
Brittany Achor
705 Reputation
6 Anleitungen geschrieben
USF Tampa, Team S1-G1, Nance Spring 2018 Mitglied von USF Tampa, Team S1-G1, Nance Spring 2018
USFT-NANCE-S18S1G1
4 Mitglieder
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 1
Insgesamt: 166
