Einleitung
Use this guide if your Huawei Union’s speaker will not play sound while watching videos or listening to music.
Was du brauchst
Wedge your thumb nail, or the flat end of a spudger, into the bottom left corner and pry off.
Use the flat end of a spudger, or fingernail, to lift up the battery and pull out.
Remove the thirteen 3mm Phillips #00 screws from the back panel.
Use the flat end of a spudger to lift the speaker out of the frame and remove.
