Zum Hauptinhalt wechseln
Huawei Watch Jewel Battery Replacement
Was du brauchst
  1. Huawei Watch Jewel Battery Replacement, Strap: Schritt 1, Bild 1 von 2 Huawei Watch Jewel Battery Replacement, Strap: Schritt 1, Bild 2 von 2
    • Begin by laying the watch on a flat, smooth surface.
    • This will prevent the watch screen from suffering damage.
    • Obtain a Flex Extension with a Size 1.0 mm flat-head. In the case of not having said tool, for this model of watch one can use the hands to replace the strap.
  2. Huawei Watch Jewel Battery Replacement: Schritt 2, Bild 1 von 2 Huawei Watch Jewel Battery Replacement: Schritt 2, Bild 2 von 2
    • Locate the two springs on the back of your watch.
    • The watch comes with two of these springs on each side of the back-face. These are used to release the straps from the body of the watch.
  3. Huawei Watch Jewel Battery Replacement: Schritt 3, Bild 1 von 3 Huawei Watch Jewel Battery Replacement: Schritt 3, Bild 2 von 3 Huawei Watch Jewel Battery Replacement: Schritt 3, Bild 3 von 3
    • Use the Flex Extension to push the spring to the right. This will release the strap from the watch head.
  4. Huawei Watch Jewel Battery Replacement: Schritt 4, Bild 1 von 1
    • Carefully pull the strap away from the watch.
  5. Huawei Watch Jewel Battery Replacement: Schritt 5, Bild 1 von 2 Huawei Watch Jewel Battery Replacement: Schritt 5, Bild 2 von 2
    • Repeat step 3, this time using the other strap.
  6. Huawei Watch Jewel Battery Replacement, Motherboard: Schritt 6, Bild 1 von 1
    • Locate the 4 T3 screws in the back of your watch, and use the T3 Torx Screwdriver to unscrew them.
  7. Huawei Watch Jewel Battery Replacement: Schritt 7, Bild 1 von 2 Huawei Watch Jewel Battery Replacement: Schritt 7, Bild 2 von 2
    • Use the Metal Spudger to pry open the back of your watch.
    • Make sure the watch is off and not plugged in when prying into the case with the Metal Spudger to avoid the risk of electric shock.
  8. Huawei Watch Jewel Battery Replacement: Schritt 8, Bild 1 von 1
    • Remove the back case.
  9. Huawei Watch Jewel Battery Replacement: Schritt 9, Bild 1 von 2 Huawei Watch Jewel Battery Replacement: Schritt 9, Bild 2 von 2
    • Use tweezers or a nylon spudger to pry up the four press-fit connectors.
    • The glued-down connector in the middle is harder to remove than the rest. That is perfectly fine.
  10. Huawei Watch Jewel Battery Replacement: Schritt 10, Bild 1 von 1
    • Locate the two Phillips #00 screws holding down the motherboard, and use the Phillips #00 screwdriver to remove them.
    • Ensure to place these screws separately from the Torx screws, as they can easily be mixed up.
  11. Huawei Watch Jewel Battery Replacement: Schritt 11, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Spudger
    $2.99
    Kaufen
    • Use the Metal Spudger to lift the mother board from the watch.
    • The metal spudger may cause damage to the device, use a black nylon spudger when possible.
  12. Huawei Watch Jewel Battery Replacement: Schritt 12, Bild 1 von 1
    • Remove the motherboard.
  13. Huawei Watch Jewel Battery Replacement, Battery: Schritt 13, Bild 1 von 1
    iFixit Opening Picks (Set of 6)
    Kaufen
    • Use the spudger or opening pick to carefully lift the battery from the watch.
    • Ensure that the polarity (+/- signs) of the new battery match that of the old battery when inserting new battery into device.
    • Avoid using a metal spudger as it may cause damage to the battery or device. Use an opening pick when possible.
Abschluss
19 weitere Nutzer:innen haben diese Anleitung absolviert.
ngan tran
498 Reputation
2 Anleitungen geschrieben
USF Tampa, Team 5-3, Passmore Spring 2017 Mitglied von USF Tampa, Team 5-3, Passmore Spring 2017
USFT-PASSMORE-S17S5G3
4 Mitglieder
3 Anleitungen geschrieben
8 Kommentare
Any idea where one can purchase the actual battery? I can’t find one anywhere.
Chris Wellings - Antwort
@Chris wellings: i was able to find one on ebay. Arrived quite quickly. And you definitely need a T2(not 3) screwdriver to open up the watch.
edgar.dumea - Antwort
Also found one on eBay. I was replacing the battery on the standard Huawei Watch (W1) and this guide was really helpful.
Alex Swanson -
thanks for this great guide, it’s very clear. My W1’s battery is still OK, but I’m anticipating needing to change it sometime and your guide removes the fear!
Paul M - Antwort
T2 or T3 Torx ???
Carlos - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 22
Letzte 30 Tage: 100
Insgesamt: 22,137
