Einleitung
Use this guide to replace the motherboard in your Huawei Watch Jewel. A damaged motherboard could be the cause for several different malfunctions regarding the watch, as it acts as the brain of the device. The screws used to hold together the watch are quite small, so handle them with care.
Was du brauchst
Begin by laying the watch on a flat, smooth surface.
Obtain a Flex Extension with a Size 1.0 mm flat-head. In the case of not having said tool, for this model of watch one can use the hands to replace the strap.
Use the Flex Extension to push the spring to the right. This will release the strap from the watch head.
Locate the 4 T3 screws in the back of your watch, and use the T3 Torx Screwdriver to unscrew them.
Locate the two Phillips #00 screws holding down the motherboard, and use the Phillips #00 screwdriver to remove them.
In diesem Schritt verwendetes Werkzeug:Spudger$2.99
Use the Metal Spudger to lift the mother board from the watch.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
