Zum Hauptinhalt wechseln
Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement
Was du brauchst
Einführungsvideo
  1. Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement, Switch off the device: Schritt 1, Bild 1 von 3 Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement, Switch off the device: Schritt 1, Bild 2 von 3 Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement, Switch off the device: Schritt 1, Bild 3 von 3
    • Turn off the device
    • Remove the sim tray
  2. Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement, Back Cover: Schritt 2, Bild 1 von 3 Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement, Back Cover: Schritt 2, Bild 2 von 3 Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement, Back Cover: Schritt 2, Bild 3 von 3
    • Use Plastic tool to separate the back cover
    • With a Phillips screwdriver remove two black screws and the battery flex connector shield
    • Disconnect the battery and the finger print sensor flex cable
  3. Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement, Logic Board Removal Part 1: Schritt 3, Bild 1 von 3 Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement, Logic Board Removal Part 1: Schritt 3, Bild 2 von 3 Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement, Logic Board Removal Part 1: Schritt 3, Bild 3 von 3
    • Remove all screws from the top of the logic board
    • Remove the shield covering the camera connectors
    • Remove the screws and the plastic cover at the bottom of the device
    • Be careful! Different colored screws have different size
  4. Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement, Logic Board Removal - Part 2: Schritt 4, Bild 1 von 3 Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement, Logic Board Removal - Part 2: Schritt 4, Bild 2 von 3 Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement, Logic Board Removal - Part 2: Schritt 4, Bild 3 von 3
    • Disconnect the Screen Flex cable
    • Remove the logic board
    • Note that at the bottom side of board is attached to the display with double-sided tape
  5. Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement: Schritt 5, Bild 1 von 3 Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement: Schritt 5, Bild 2 von 3 Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement: Schritt 5, Bild 3 von 3
    • Now you have to transfer:
    • Receiver
    • Proximity sensor
    • Volume buttons flex
    • Vibration
    • Battery
Abschluss
11 weitere Nutzer:innen haben diese Anleitung absolviert.
ZFix
191.470 Reputation
330 Anleitungen geschrieben
Master Techs Mitglied von Master Techs
Community
321 Mitglieder
1.485 Anleitungen geschrieben
Ein Kommentar
Can i get video guide
filmon - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 23
Letzte 30 Tage: 84
Insgesamt: 6,655
