Was du brauchst
Einführungsvideo
Switch off the device.
Remove the SIM Tray.
Use plastic opening tool to remove the back / battery cover.
Gently disconnect the Fingerprint Flex Cable.
Unscrew the 7 Phillips screws.
Use the plastic tool to unstick the daughter board plastic cover.
Gently disconnect the main flex and the coaxial antenna cable.
Use Plastic tool to remove the charging board.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
