Einleitung
An outline to teach others what they are about to do.
unhook Central frame using a thin tool behind joints along the entire perimeter of the phone
Unplug the touchscreen connector.
Unplug the motherboard connector.
Unplug the side volume key connector.
Remove the camera with a heat source because it's glued to the bottom.
Remove the motherboard from the main body of the phone.
Remove the power button using a heat source.
Remove the volume key using a heat source.
Remove the speaker cover.
Using a heat source, delicately remove the daughterboard.
Remove the speaker using a heat source.
Remove the technical adhesive strips using a heat source.
To reassemble the device, follow this instructions in reverse order.
5 weitere Nutzer:innen haben diese Anleitung absolviert.
100%
Hier starten ›
