Zum Hauptinhalt wechseln
Huawei u7519 Camera Replacement
Was du brauchst
  1. Huawei u7519 Camera Replacement, Back Cover: Schritt 1, Bild 1 von 2 Huawei u7519 Camera Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Take off the back covering of the phone along with the battery and SIM card.
    • The SIM card is located above the battery.
  2. Huawei u7519 Camera Replacement: Schritt 2, Bild 1 von 2 Huawei u7519 Camera Replacement: Schritt 2, Bild 2 von 2
    • Using the Phillips #00 Screwdriver, take out the four small screws located at the four corners of the phone.
    • Save the screws. They will be needed for reassembly.
  3. Huawei u7519 Camera Replacement: Schritt 3, Bild 1 von 1
    • Using the same screwdriver, take out the two bigger screws located on each side of the battery compartment.
    • NOTE: Save the screws. They will be needed for reassembly.
  4. Huawei u7519 Camera Replacement: Schritt 4, Bild 1 von 1
    • Once all the screws are removed, use the iPod opening tool to pry off the back covering of the phone along the edge of the back cover and you will have access to the motherboard.
    • Note: The power and volume buttons will fall out of the phone. Set aside for reassembly.
  5. Huawei u7519 Camera Replacement: Schritt 5, Bild 1 von 1
    • Carefully pull the backing of the phone from the motherboard with your hands.
  6. Huawei u7519 Camera Replacement, Camera: Schritt 6, Bild 1 von 2 Huawei u7519 Camera Replacement, Camera: Schritt 6, Bild 2 von 2
    • To remove front encasing from the motherboard, first pull back the orange tabs.
  7. Huawei u7519 Camera Replacement: Schritt 7, Bild 1 von 2 Huawei u7519 Camera Replacement: Schritt 7, Bild 2 von 2
    • Once the orange tabs are pulled back, carefully pull the motherboard apart from the front casing.
  8. Huawei u7519 Camera Replacement: Schritt 8, Bild 1 von 1
    • The camera is not removable from the motherboard. Therefore, a new motherboard must be purchased in order to replace the camera.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Ohio State, Team 1-1, Meza Spring 2014 Mitglied von Ohio State, Team 1-1, Meza Spring 2014
OSU-MEZA-S14S1G1
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 14
Insgesamt: 523
