Zum Hauptinhalt wechseln
Huffy Kids Tricycle Seat Replacement
Was du brauchst
  1. Huffy Kids Tricycle Seat Replacement, Seat: Schritt 1, Bild 1 von 2 Huffy Kids Tricycle Seat Replacement, Seat: Schritt 1, Bild 2 von 2
    • Focus on the seat area for the replacement.
  2. Huffy Kids Tricycle Seat Replacement: Schritt 2, Bild 1 von 2 Huffy Kids Tricycle Seat Replacement: Schritt 2, Bild 2 von 2
    • Place the spanner on the bolt on the underside of the seat.
    • Then use a Phillips #2 screwdriver to remove the screw on the top of the seat.
  3. Huffy Kids Tricycle Seat Replacement: Schritt 3, Bild 1 von 3 Huffy Kids Tricycle Seat Replacement: Schritt 3, Bild 2 von 3 Huffy Kids Tricycle Seat Replacement: Schritt 3, Bild 3 von 3
    • Repeat for the other screw.
  4. Huffy Kids Tricycle Seat Replacement: Schritt 4, Bild 1 von 3 Huffy Kids Tricycle Seat Replacement: Schritt 4, Bild 2 von 3 Huffy Kids Tricycle Seat Replacement: Schritt 4, Bild 3 von 3
    • Lift the seat off of the trike frame.
  5. Huffy Kids Tricycle Seat Replacement: Schritt 5, Bild 1 von 3 Huffy Kids Tricycle Seat Replacement: Schritt 5, Bild 2 von 3 Huffy Kids Tricycle Seat Replacement: Schritt 5, Bild 3 von 3
    • Place the new seat on the seat bracket, lining up the screw holes in the seat with the appropriate holes on the bracket.
    • Note that the bracket has two sets of holes for mounting the seat, so choose the appropriate set for the height of the rider. A taller rider will use the further set while a shorter rider will use the set closer to the handlebars.
    • Insert the screws from the top of the seat, using your spanner to hold the nuts under the screws.
  6. Huffy Kids Tricycle Seat Replacement: Schritt 6, Bild 1 von 2 Huffy Kids Tricycle Seat Replacement: Schritt 6, Bild 2 von 2
    • Give the seat a wiggle to check that it is tight against the bracket.
    • If there is any play, tighten the screws a few more turns.
Abschluss
To reassemble your device, follow these instructions in reverse order and you should be able to accomplish this
York University, Team F-4, Woodhouse Fall 2021 Mitglied von York University, Team F-4, Woodhouse Fall 2021
YORK-WOODHOUSE-F21SFG4
1 Mitglied
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 20
Insgesamt: 616
