Zum Hauptinhalt wechseln
Husqvarna Viking Designer 1 Needle Replacement
Was du brauchst
  1. Husqvarna Viking Designer 1 Needle Replacement, Needle: Schritt 1, Bild 1 von 2 Husqvarna Viking Designer 1 Needle Replacement, Needle: Schritt 1, Bild 2 von 2
    • Remove the thread from the needle by pulling it out.
  2. Husqvarna Viking Designer 1 Needle Replacement: Schritt 2, Bild 1 von 3 Husqvarna Viking Designer 1 Needle Replacement: Schritt 2, Bild 2 von 3 Husqvarna Viking Designer 1 Needle Replacement: Schritt 2, Bild 3 von 3
    • Turn the knob counterclockwise to life up the needle.
    • Turning the knob clockwise can damage the machine.
  3. Husqvarna Viking Designer 1 Needle Replacement: Schritt 3, Bild 1 von 1
    • Place a sheet of paper under the foot. In the event that the needle falls out, this will prevent it from falling into the bobbin area.
  4. Husqvarna Viking Designer 1 Needle Replacement: Schritt 4, Bild 1 von 2 Husqvarna Viking Designer 1 Needle Replacement: Schritt 4, Bild 2 von 2
    • Hold onto the needle with one hand, and use a Singer #412381501 screwdriver to loosen the needle clamp screw (model: Viking #4125825-01) located next to the top of the needle with the other hand.
  5. Husqvarna Viking Designer 1 Needle Replacement: Schritt 5, Bild 1 von 1
    • Discard the broken or unwanted needle, and select a new one.
  6. Husqvarna Viking Designer 1 Needle Replacement: Schritt 6, Bild 1 von 2 Husqvarna Viking Designer 1 Needle Replacement: Schritt 6, Bild 2 von 2
    • Insert the new needle with the flat side facing away from you.
  7. Husqvarna Viking Designer 1 Needle Replacement: Schritt 7, Bild 1 von 1
    • Hold onto the needle with one hand, and use a Singer #412381501 screwdriver to tighten the needle clamp screw (model: Viking #4125825-01) with the other hand.
  8. Husqvarna Viking Designer 1 Needle Replacement: Schritt 8, Bild 1 von 1
    • Thread the needle. (See pages 8-10 from the link.)
    • You may now remove the sheet of paper and begin sewing!
Abschluss
Replacing the needle is a quick, easy task to complete, using the directions provided in this guide.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ein Kommentar
Excellent illustration!!!
KO SAMUEL TAK SHUN - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 4
Letzte 30 Tage: 41
Insgesamt: 1,278
