Zum Hauptinhalt wechseln
HyperX QuadCast S Gain Control Knob Replacement
  1. HyperX QuadCast S Gain Control Knob Replacement, Gain Control Knob: Schritt 1, Bild 1 von 3 HyperX QuadCast S Gain Control Knob Replacement, Gain Control Knob: Schritt 1, Bild 2 von 3 HyperX QuadCast S Gain Control Knob Replacement, Gain Control Knob: Schritt 1, Bild 3 von 3
    • Set the microphone on a flat surface.
    • Pull each of the support bands upwards and off of the notches to release the microphone from its base.
    • There are four support bands in total, but it does not matter which band you choose to take off first.
  2. HyperX QuadCast S Gain Control Knob Replacement: Schritt 2, Bild 1 von 3 HyperX QuadCast S Gain Control Knob Replacement: Schritt 2, Bild 2 von 3 HyperX QuadCast S Gain Control Knob Replacement: Schritt 2, Bild 3 von 3
    • Orientate the microphone with the gain control knob upwards.
    • Pull outwards from the microphone to release the gain control knob.
    • It will not take much force to release the knob from the microphone. Be aware that a small "pop" may be heard once the knob is unplugged.
  3. HyperX QuadCast S Gain Control Knob Replacement: Schritt 3, Bild 1 von 3 HyperX QuadCast S Gain Control Knob Replacement: Schritt 3, Bild 2 von 3 HyperX QuadCast S Gain Control Knob Replacement: Schritt 3, Bild 3 von 3
    • Remove the gain control knob.
    • The gain control knob connects to the tiny black pin indicated. When reattaching the knob, make sure to properly align the hole to the shape of the pin.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Nathan Arruda
711 Reputation
6 Anleitungen geschrieben
UMass Dartmouth, Team 4-1, Sinclaire Fall 2022 Mitglied von UMass Dartmouth, Team 4-1, Sinclaire Fall 2022
UMASSD-SINCLAIRE-F22S4G1
5 Mitglieder
9 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 15
Letzte 30 Tage: 89
Insgesamt: 1,172
