Einleitung
Remove the keypad of the TC-580. This will require serious disassembly of the radio. If you aren't able to get the buttons to work or the radio doesn't seem to respond properly to key presses you should consider doing this.
Was du brauchst
Remove grey nut from base of volume knob by turning it counterclockwise with a set of tweezers.
Remove the brass washer from the base of the antenna slot by turning it counterclockwise with a set of tweezers.
Using a plastic opening tool, pry in between the plastic case and metal circuit board to remove the board.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
