Einleitung
Remove and replace the microphone built into the TC-580 circuit board. This will require soldering that could permanently damage the circuit board of your radio so please consider other options for repair. This repair is for users that can't have other parties hear them on the radio.
Was du brauchst
Remove grey nut from base of volume knob by turning it counterclockwise with a set of tweezers.
Remove the brass washer from the base of the antenna slot by turning it counterclockwise with a set of tweezers.
Using a plastic opening tool, pry in between the plastic case and metal circuit board to remove the board.
Apply a soldering iron to the solder joints to remove the two wires connecting the speaker to the circuit board.
If not already done, remove the circuit board completely from the case.
