Zum Hauptinhalt wechseln
Hytera TC-580 Speaker Replacement
Was du brauchst
  1. Hytera TC-580 Speaker Replacement, Battery: Schritt 1, Bild 1 von 2 Hytera TC-580 Speaker Replacement, Battery: Schritt 1, Bild 2 von 2
    • Remove the two 10mm Phillips #0 from the belt clip.
  2. Hytera TC-580 Speaker Replacement: Schritt 2, Bild 1 von 2 Hytera TC-580 Speaker Replacement: Schritt 2, Bild 2 von 2
    • Push in the release button and pull up on the battery to remove.
  3. Hytera TC-580 Speaker Replacement, Antenna: Schritt 3, Bild 1 von 1
    • Twist antenna counter-clockwise and set damaged antenna aside.
  4. Hytera TC-580 Speaker Replacement, Keypad: Schritt 4, Bild 1 von 1
    • Remove the volume knob by firmly lifting up on both sides of it.
  5. Hytera TC-580 Speaker Replacement: Schritt 5, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Remove the orange o-ring around volume knob using tweezers.
  6. Hytera TC-580 Speaker Replacement: Schritt 6, Bild 1 von 1
    • Remove grey nut from base of volume knob by turning it counterclockwise with a set of tweezers.
  7. Hytera TC-580 Speaker Replacement: Schritt 7, Bild 1 von 1
    • Remove the brass washer from the base of the antenna slot by turning it counterclockwise with a set of tweezers.
  8. Hytera TC-580 Speaker Replacement: Schritt 8, Bild 1 von 2 Hytera TC-580 Speaker Replacement: Schritt 8, Bild 2 von 2
    • Remove the two 15mm T8 Torx screws from the base of the battery cavity.
  9. Hytera TC-580 Speaker Replacement: Schritt 9, Bild 1 von 1
    • Using a plastic opening tool, pry in between the plastic case and metal circuit board to remove the board.
  10. Hytera TC-580 Speaker Replacement: Schritt 10, Bild 1 von 1
    • Peel off the keypad by hand.
  11. Hytera TC-580 Speaker Replacement, Speaker: Schritt 11, Bild 1 von 3 Hytera TC-580 Speaker Replacement, Speaker: Schritt 11, Bild 2 von 3 Hytera TC-580 Speaker Replacement, Speaker: Schritt 11, Bild 3 von 3
    • Remove eleven 4mm Phillips #00 screws.
  12. Hytera TC-580 Speaker Replacement: Schritt 12, Bild 1 von 1
    • Apply a soldering iron to the solder joints to remove the two wires connecting the speaker to the circuit board.
Abschluss
Mohammed Chehab
88 Reputation
1 Anleitung geschrieben
USF Tampa, Team S3-G4, Nance Spring 2018 Mitglied von USF Tampa, Team S3-G4, Nance Spring 2018
USFT-NANCE-S18S3G4
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 13
Insgesamt: 505
