Einleitung
Use this guide to replace the brake light bulb on the Hyundai Santa Fe Sport.
The brake lights are something that frequently needs replacing compared to other parts and it is important to make sure your brake lights are functioning properly. It will become dangerous to drive around in a car with no brake lights.
There are many other light bulbs to be used as brake lights available, but the one I recommend is the Sylvia 2357 long life mini bulb.
Was du brauchst
Remove the black plastic cover located on the inner side taillight by using a #2 flat head screwdriver.
Slide out the headlights placing one hand on the outer side and the other hand gripped onto the back of the taillight, pulling straight out.
Turn the grey brake light socket with the multi-colored wires connected to it counterclockwise.
Pull out the light bulb from the grey bulb socket by pushing downwards while turning counterclockwise.
Take the new replacement bulb and insert it into the light socket while pushing down onto the bulb, turning clockwise and securing the bulb in place.
Slide the light socket back into the circular compartment, making sure the bulb is facing inwards.
After inserted, turn it clockwise to lock the bulb back into place.
Slide the taillight back into the starting position.
Align the taillight with a circular piece on the outer side of the car.
Take the two 12 mm Phillip #2 screws and place them back into the two visible holes.
Replace the plastic cover by pushing down on all of the corners.
Once the plastic piece is fixed onto the car, you can then close the trunk.
You have now completed the guide, to replace the brake bulb on your 2012 - 2018 Hyundai Santa Fe Sport.
5 weitere Personen haben diese Anleitung absolviert.
2 Kommentare
Follow these steps and you can't go wrong. Nicely done.
