Was du brauchst
Open the key. Using a small screwdriver gently push in the plastic clips at the marked points. One by one. You have to push up the lid a bit at this side.
Replace the battery with a new one. Battery type: CR2032 (3V)
Follow the steps backwards to assemble the unit.
Fast fertig!
Abschluss
Ein Kommentar
East as promised. One remark only: You need a PH1 screwdriver when working the brass ("yellow") screws.
