Einleitung
when the battery dead you need to set the system date every time the laptop starts. They guide shows you how I fix this with $1.
Was du brauchst
Just unscrew 4 screws to loose the KB, there are plenty guides / video on Google so I won't go in to details here.
Carefully disconnect the battery from the mainboard micro socket.
Cut the yellow plastic cover, try to cut if as half circle and KEEP it for later use.
The connector is soldered to the battery, use a small slot head screw driver to break the soldering slowly.
You may notice the battery is just a CR2025 cell, which costs $1
Transfer the blue plastic "ring" from the old battery to the new one, you can do it nicely by using a cutter. This isolation is essential to avoid the connector being short circuit
The metal part need to be flatten with a wire clamp or whatever can help you
It is difficult to solder the cell with home equipment. I used adhesive tape to stick the metal contacts to the cell, RED wire to +ve and BLACK/WHITE wire to -ve
You have to avoid the metal contacts from short circuit, adhesive tapes can help you
I didn't have the contracting tubes that fit the cell which is 2cm diameter. Remember the cut yellow shield in step1? Use it to cover the metal parts and reconnect the battery
3 weitere Personen haben diese Anleitung absolviert.
Ein Kommentar
“there are plenty guides / video on Google so I won't go in to details here.” Really? That’s a really $@$*!& guide stating what your looking for in the beginning. :(
