Zum Hauptinhalt wechseln
IBM ThinkPad 560z Keyboard Replacement
Was du brauchst
  1. IBM ThinkPad 560z Keyboard Replacement, Upper Case: Schritt 1, Bild 1 von 1
    • Remove the 7 mm Phillips #0 screws.
    • Remove the 10 mm Phillips #0 screws.
    • Remove the 14 mm Phillips #0 screw.
  2. IBM ThinkPad 560z Keyboard Replacement: Schritt 2, Bild 1 von 2 IBM ThinkPad 560z Keyboard Replacement: Schritt 2, Bild 2 von 2
    • Open the flap on the left hand side.
  3. IBM ThinkPad 560z Keyboard Replacement: Schritt 3, Bild 1 von 2 IBM ThinkPad 560z Keyboard Replacement: Schritt 3, Bild 2 von 2
    • Insert the plastic opening tools between the right and left sides of the latch.
    • Pry the right side of the latch, and then pry the left side to detach the laptop's cover.
  4. IBM ThinkPad 560z Keyboard Replacement: Schritt 4, Bild 1 von 2 IBM ThinkPad 560z Keyboard Replacement: Schritt 4, Bild 2 von 2
    • Open the flap on the right side.
  5. IBM ThinkPad 560z Keyboard Replacement: Schritt 5, Bild 1 von 1
    • Insert the plastic opening tools towards the right side of the latch.
    • Gently pry the right side out to release the top cover.
  6. IBM ThinkPad 560z Keyboard Replacement: Schritt 6, Bild 1 von 2 IBM ThinkPad 560z Keyboard Replacement: Schritt 6, Bild 2 von 2
    • Lift the keyboard slowly.
    • A cable connects the keyboard to the motherboard. If you are not careful, you will damage the cable.
  7. IBM ThinkPad 560z Keyboard Replacement: Schritt 7, Bild 1 von 1
    • Use your fingers or a spudger to detach the connector.
  8. IBM ThinkPad 560z Keyboard Replacement: Schritt 8, Bild 1 von 2 IBM ThinkPad 560z Keyboard Replacement: Schritt 8, Bild 2 von 2
    • Carefully lift and remove the keyboard.
  9. IBM ThinkPad 560z Keyboard Replacement, Keyboard Removal: Schritt 9, Bild 1 von 2 IBM ThinkPad 560z Keyboard Replacement, Keyboard Removal: Schritt 9, Bild 2 von 2
    • Remove the five Phillips screws from the underside of the keyboard, then gently lift it up.
Abschluss
Cal Poly, Team 26-27, Regan Spring 2010 Mitglied von Cal Poly, Team 26-27, Regan Spring 2010
CPSU-REGAN-S10S26G27
3 Mitglieder
18 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 12
Insgesamt: 2,451
