Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
This guide will demonstrate how to remove and replace the screen on an IBM ThinkPad 560z. A Phillips 00 screwdriver and a push pin are needed for this process.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Slide the battery release latch to the right.
    • Slide the battery release latch to the right.
    • Pull out the battery out towards the front of the device.
  2. Remove the plastic screw covers, then remove the 3 Phillips screws under them. Remove the plastic screw covers, then remove the 3 Phillips screws under them.
    • Remove the plastic screw covers, then remove the 3 Phillips screws under them.
  3. Insert the plastic opening tool between the front cover and back cover to pry open the screen case, then carefully pull the bezel off.
    • Insert the plastic opening tool between the front cover and back cover to pry open the screen case, then carefully pull the bezel off.
  4. Remove the four Phillips head screws.
    • Remove the four Phillips head screws.
  5. Using your fingers or an Opening Tool, detach the connector on the right side of the screen.
    • Using your fingers or an Opening Tool, detach the connector on the right side of the screen.
  6. Slowly pull back the screen from the top and disconnect the ribbon cable from the back to completely free the screen from the laptop. The connector is very fragile, so be careful.
    • Slowly pull back the screen from the top and disconnect the ribbon cable from the back to completely free the screen from the laptop.
    • The connector is very fragile, so be careful.
Abschluss
2 weitere Nutzer haben diese Anleitung absolviert.
John Allande
64 Reputation
1 Anleitung geschrieben
Cal Poly, Team 26-27, Regan Spring 2010 Mitglied von Cal Poly, Team 26-27, Regan Spring 2010
CPSU-REGAN-S10S26G27
3 Mitglieder
18 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 3
Letzten 30 Tage: 5
Insgesamt: 4,656
