Einleitung
This guide will show you how to replace your display from your laptop. You would need to replace it if you break your display.
Was du brauchst
In diesem Schritt verwendetes Werkzeug:Anti-Static Wrist Strap$7.95
Unscrew the coin screw for the hard drive using a coin. Pry off the HDD cover.
Unlock the highlighted latch and pull the disk drive out.
Remove the disk drive.
Four 18mm long M2.5 screws
Two 16mm long M2.5 screws
One 4.5mm long M2.5 screws
Four 3mm long M2.5 screws
Open the laptop all the way until it is flat.
Take the black circle off and remove the screw.
Pry the keyboard case up from the bottom and gently pry it up from all other edges.
Pry the connectors of the ribbon cables off slowly, lifting straight up. Wiggle gently side to side if necessary.
Remove the plastic part attached to the bottom of the screen.
Gently pull it from one side and then from another.
Close the laptop and turn it around. There you will see 4 more screws.
Unscrew highlighted screws.
Four 4.8mm long M2.5 screws
After you've removed the screws, open the laptop and gently pull the display out.
Eine weitere Person hat diese Anleitung absolviert.
