Einleitung
This guide will show you how to replace your hard drive disk. Several reasons why you would want to replace your hard drive is because you want to increase your memory or it is faulty or broken.
Was du brauchst
Using a screwdriver, remove the screws by turning them counterclockwise to remove the bracket.
four 3mm PH0 screws
The top plastic piece is adhered with a weak adhesive. Gently pry it off with a spudger.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
