Einleitung
This guide will show you how to replace the RAM from your laptop. There are several reasons to replace your RAM. The most common reason is to increase your RAM memory. Other reasons could be that it could faulty or damaged.
Was du brauchst
Using a screwdriver, loosen but do not remove the captive screw by turning counterclockwise.
One 3mm PH0 screw
2 weitere Personen haben diese Anleitung absolviert.
