Zum Hauptinhalt wechseln
IBM ThinkPad A31 CPU Replacement
Was du brauchst
  1. IBM ThinkPad A31 CPU Replacement, Hard Drive: Schritt 1, Bild 1 von 3 IBM ThinkPad A31 CPU Replacement, Hard Drive: Schritt 1, Bild 2 von 3 IBM ThinkPad A31 CPU Replacement, Hard Drive: Schritt 1, Bild 3 von 3
    • Remove the 6mm screw
    • Pull out the hard drive
    • The hard drive might be a little tough to pull out
  2. IBM ThinkPad A31 CPU Replacement, Keyboard: Schritt 2, Bild 1 von 3 IBM ThinkPad A31 CPU Replacement, Keyboard: Schritt 2, Bild 2 von 3 IBM ThinkPad A31 CPU Replacement, Keyboard: Schritt 2, Bild 3 von 3
    • The sticker is to keep the warranty on the laptop so once removed the warranty is void
    • Peel the sticker and remove the 15mm screw
    • Remove all 6 of the 16mm screws
  3. IBM ThinkPad A31 CPU Replacement: Schritt 3, Bild 1 von 2 IBM ThinkPad A31 CPU Replacement: Schritt 3, Bild 2 von 2
    • use a prying tool and insert it on the cracks on the sides of the keyboard and lift gently until you here a click
    • repeat this step on all sides of the keyboard until the keyboard is completely detached from the laptop
  4. IBM ThinkPad A31 CPU Replacement: Schritt 4, Bild 1 von 3 IBM ThinkPad A31 CPU Replacement: Schritt 4, Bild 2 von 3 IBM ThinkPad A31 CPU Replacement: Schritt 4, Bild 3 von 3
    • Lift the keyboard and remove the keyboard ribbon cable from the laptop
  5. IBM ThinkPad A31 CPU Replacement, Display: Schritt 5, Bild 1 von 2 IBM ThinkPad A31 CPU Replacement, Display: Schritt 5, Bild 2 von 2
    • Remove the one 21mm screw
  6. IBM ThinkPad A31 CPU Replacement: Schritt 6, Bild 1 von 2 IBM ThinkPad A31 CPU Replacement: Schritt 6, Bild 2 von 2
    • Take the tool and run it under the black case.
  7. IBM ThinkPad A31 CPU Replacement: Schritt 7, Bild 1 von 3 IBM ThinkPad A31 CPU Replacement: Schritt 7, Bild 2 von 3 IBM ThinkPad A31 CPU Replacement: Schritt 7, Bild 3 von 3
    • Unscrew the 2 (17mm) screws
    • Unscrew the 6mm screw
  8. IBM ThinkPad A31 CPU Replacement: Schritt 8, Bild 1 von 2 IBM ThinkPad A31 CPU Replacement: Schritt 8, Bild 2 von 2
    • Gently disconnect the white display ribbon cable
    • Pulling on the ribbon cable too hard could result in worse or faulty connection.
  9. IBM ThinkPad A31 CPU Replacement: Schritt 9, Bild 1 von 3 IBM ThinkPad A31 CPU Replacement: Schritt 9, Bild 2 von 3 IBM ThinkPad A31 CPU Replacement: Schritt 9, Bild 3 von 3
    • Unscrew 4 (6mm) screws
    • Lift screen straight up
    • If not lifted straight up the screen could get damaged
  10. IBM ThinkPad A31 CPU Replacement, Battery: Schritt 10, Bild 1 von 2 IBM ThinkPad A31 CPU Replacement, Battery: Schritt 10, Bild 2 von 2
    • Flip the ThinkPad over so that it is upside down.
    • Push latch switch to the left.
    • Gently lift the battery out and away from the ThinkPad
    • You have to hold the latch to the left while you remove the battery. Simply pushing once will not unlock the battery
  11. IBM ThinkPad A31 CPU Replacement, CPU: Schritt 11, Bild 1 von 3 IBM ThinkPad A31 CPU Replacement, CPU: Schritt 11, Bild 2 von 3 IBM ThinkPad A31 CPU Replacement, CPU: Schritt 11, Bild 3 von 3
    • LIft the bracket out
  12. IBM ThinkPad A31 CPU Replacement: Schritt 12, Bild 1 von 3 IBM ThinkPad A31 CPU Replacement: Schritt 12, Bild 2 von 3 IBM ThinkPad A31 CPU Replacement: Schritt 12, Bild 3 von 3
    • Remove one 6mm screw
    • Remove 3 18mm screws
    • Take off the bracket on the CPU fan
  13. IBM ThinkPad A31 CPU Replacement: Schritt 13, Bild 1 von 3 IBM ThinkPad A31 CPU Replacement: Schritt 13, Bild 2 von 3 IBM ThinkPad A31 CPU Replacement: Schritt 13, Bild 3 von 3
    • Lift the CPU fan
    • Pull out the cable attached to the motherboard
  14. IBM ThinkPad A31 CPU Replacement: Schritt 14, Bild 1 von 2 IBM ThinkPad A31 CPU Replacement: Schritt 14, Bild 2 von 2
    • Turn the locking screw to unlock with the flat head screwdriver
    • LIft the CPU out
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Thomas Stone
235 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team S2-G2, Bernier Spring 2018 Mitglied von UMass Dartmouth, Team S2-G2, Bernier Spring 2018
UMASSD-BERNIER-S18S2G2
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 9
Insgesamt: 886
