Was du brauchst
Peel the sticker and remove the 15mm screw
Remove all 6 of the 16mm screws
use a prying tool and insert it on the cracks on the sides of the keyboard and lift gently until you here a click
repeat this step on all sides of the keyboard until the keyboard is completely detached from the laptop
Flip the ThinkPad over so that it is upside down.
Push latch switch to the left.
Gently lift the battery out and away from the ThinkPad
Turn the locking screw to unlock with the flat head screwdriver
LIft the CPU out
Eine weitere Person hat diese Anleitung absolviert.
