Ersatzteile
Kein Ersatzteil erforderlich.
  1. The sticker is to keep the warranty on the laptop so once removed the warranty is void Peel the sticker and remove the 15mm screw Remove all 6 of the 16mm screws
    • The sticker is to keep the warranty on the laptop so once removed the warranty is void
    • Peel the sticker and remove the 15mm screw
    • Remove all 6 of the 16mm screws
  2. use a  prying tool and insert it on the cracks on the sides of the keyboard and lift gently until you here a click repeat this step on all sides of the keyboard until the keyboard is completely detached from the laptop
    • use a prying tool and insert it on the cracks on the sides of the keyboard and lift gently until you here a click
    • repeat this step on all sides of the keyboard until the keyboard is completely detached from the laptop
  3. Lift the keyboard and remove the keyboard ribbon cable  from the laptop Lift the keyboard and remove the keyboard ribbon cable  from the laptop Lift the keyboard and remove the keyboard ribbon cable  from the laptop
    • Lift the keyboard and remove the keyboard ribbon cable from the laptop
  4. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  5. Remove the one 21mm screw Remove the 6mm screw
    • Remove the one 21mm screw
    • Remove the 6mm screw
  6. Take the tool and run it under the black case. Take the tool and run it under the black case.
    • Take the tool and run it under the black case.
  7. Unscrew the 2 (17mm) screws Unscrew the 6mm screw Unscrew the 6mm screw
    • Unscrew the 2 (17mm) screws
    • Unscrew the 6mm screw
  8. Gently disconnect the white display ribbon cable Pulling on the ribbon cable too hard could result in worse or faulty connection.
    • Gently disconnect the white display ribbon cable
    • Pulling on the ribbon cable too hard could result in worse or faulty connection.
  9. Unscrew 4 (6mm) screws Lift screen straight up If not lifted straight up the screen could get damaged
    • Unscrew 4 (6mm) screws
    • Lift screen straight up
    • If not lifted straight up the screen could get damaged
Abschluss
Sean Tocci
293 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team S2-G2, Bernier Spring 2018 Mitglied von UMass Dartmouth, Team S2-G2, Bernier Spring 2018
UMASSD-BERNIER-S18S2G2
3 Mitglieder
5 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 5
Insgesamt: 61
