Zum Hauptinhalt wechseln
IBM ThinkPad R40 Keyboard Keys Replacement
Was du brauchst
  1. IBM ThinkPad R40 Keyboard Keys Replacement, Disconnection: Schritt 1, Bild 1 von 1
    • Make sure your laptop is off and disconnected from the power source to ensure safety for yourself.
  2. IBM ThinkPad R40 Keyboard Keys Replacement, Replacement: Schritt 2, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Locate the key that needs replacing. Use tweezers to slowly pull the key off the keyboard. Doing this will expose the underside of the keyboard.
  3. IBM ThinkPad R40 Keyboard Keys Replacement, Set aside: Schritt 3, Bild 1 von 1
    • Step 3: Set the old key aside and have the new key ready to be inserted onto the computer. The key has three parts, which you can see here.
  4. IBM ThinkPad R40 Keyboard Keys Replacement, Moving inside: Schritt 4, Bild 1 von 1
    • The new key will have an empty slot where they key used to be. It contains a small rubber spring. After the rubber spring is inserted take the new key and line it up according to the color springs on the backside of the key along with the keyboard.
  5. IBM ThinkPad R40 Keyboard Keys Replacement, Lining up: Schritt 5, Bild 1 von 1
    • After lining the key up, the black and white pieces will line up.
  6. IBM ThinkPad R40 Keyboard Keys Replacement, Finishing up: Schritt 6, Bild 1 von 1
    • Step 6: The key should not be firmly locked into place and functioning normally.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Erin
231 Reputation
2 Anleitungen geschrieben
University of Maine, Team 1-13, Diaz Fall 2011 Mitglied von University of Maine, Team 1-13, Diaz Fall 2011
UMAINE-DIAZ-F11S1G13
1 Mitglied
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 17
Insgesamt: 4,601
