Zum Hauptinhalt wechseln
Einleitung
Removal/repair of the display
Ersatzteile
Keine Ersatzteile angegeben.
  1. IBM ThinkPad T42 Display Replacement, Bottom Cover: Schritt 1, Bild 1 von 1
    • Unscrew the 20 Phillips screws on the underside of the T42.
    • For ease of reassembly, keep your screws organized.
  2. IBM ThinkPad T42 Display Replacement, Rear Screws: Schritt 2, Bild 1 von 1
    • Unscrew the 2 Phillips screws on both sides of the T42's rear.
  3. IBM ThinkPad T42 Display Replacement, Keyboard/Trackpad Removal: Schritt 3, Bild 1 von 1
    • Flip the laptop over and open the screen.
    • The bezel and keyboard will be loose, be careful.
  4. IBM ThinkPad T42 Display Replacement, Disconnecting Ribbon Cables: Schritt 4, Bild 1 von 2 IBM ThinkPad T42 Display Replacement, Disconnecting Ribbon Cables: Schritt 4, Bild 2 von 2
    • Carefully maneuver the palm rest away from the keyboard, as both the keyboard and palm rest/trackpad will come off together.
    • Remember, both the keyboard and trackpad have connectors to the motherboard. Disconnect these before completely removing either component.
  5. IBM ThinkPad T42 Display Replacement, Bezel Removal: Schritt 5, Bild 1 von 2 IBM ThinkPad T42 Display Replacement, Bezel Removal: Schritt 5, Bild 2 von 2
    • Remove the plastic bezel along the edges, you may need to pry the areas circled with a spudger to remove the bezel.
  6. IBM ThinkPad T42 Display Replacement, Display Screws: Schritt 6, Bild 1 von 1
    • Unscrew the screws holding down the display.
    • Along with the one pictured in red, there is another one along the top right edge.
  7. IBM ThinkPad T42 Display Replacement, Display and Ribbon Cable Removal: Schritt 7, Bild 1 von 1
    • Carefully unplug the display ribbon on the motherboard, then carefully lift the display free from the device.
Abschluss
6 weitere Nutzer haben diese Anleitung absolviert.
Austin Kidd
299 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 29-76, Johann Spring 2010 Mitglied von Cal Poly, Team 29-76, Johann Spring 2010
CPSU-JOHANN-S10S29G76
4 Mitglieder
30 Anleitungen geschrieben
2 Kommentare
@Seth
Just use the pic numbering left to right each of the 4 rows.
Start at the top and remove in sequence, placing each on a strip of heavy tape to keep the screws in sequence.
Place a second strip on top when finished to secure the sequence until it's time to re-assemble.
Michael G - Antwort
Very poor & sketchy guide! NO mention at all of how to handle the other wires involved in disconnecting the screen (lid) from the laptop base, eg: the wireless antenna connections and instructions like: "Unscrew the screws holding it down" are far too vague! holding WHAT down ffs!!!!
wbcam - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 5
Letzten 30 Tage: 19
Insgesamt: 12,612
