Einleitung
The Mini-PCI port can be accessed easily after removing the rear cover
Was du brauchst
Use a Phillips #0 screwdriver to remove the twenty screws on the underside of the T42.
Remove the four Phillips screws located on either side of the rear of the T42 (there are two on each end.)
Flip the laptop over and open the screen to access the keyboard and trackpad.
Carefully maneuver the palm rest away from the keyboard, as both the keyboard and palm rest/trackpad will come off together.
Carefully disconnect it from the motherboard and pull it out of the device.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
