Zum Hauptinhalt wechseln
IBM ThinkPad T42 Mini-PCI Port Replacement
Was du brauchst
  1. IBM ThinkPad T42 Mini-PCI Port Replacement, Bottom cover: Schritt 1, Bild 1 von 1
    • Use a Phillips #0 screwdriver to remove the twenty screws on the underside of the T42.
  2. IBM ThinkPad T42 Mini-PCI Port Replacement, Rear screws: Schritt 2, Bild 1 von 1
    • Remove the four Phillips screws located on either side of the rear of the T42 (there are two on each end.)
  3. IBM ThinkPad T42 Mini-PCI Port Replacement, Keyboard and Trackpad: Schritt 3, Bild 1 von 1
    • Flip the laptop over and open the screen to access the keyboard and trackpad.
    • The keyboard and trackpad are connected to the motherboard. Before removing the keyboard and trackpad, disconnect both components from the motherboard, as shown in the following step.
    • The bezel and keyboard will be loose, be careful.
  4. IBM ThinkPad T42 Mini-PCI Port Replacement: Schritt 4, Bild 1 von 2 IBM ThinkPad T42 Mini-PCI Port Replacement: Schritt 4, Bild 2 von 2
    • Carefully maneuver the palm rest away from the keyboard, as both the keyboard and palm rest/trackpad will come off together.
    • Remember, both the keyboard and trackpad have connectors to the motherboard. Disconnect these before completely removing either component.
  5. IBM ThinkPad T42 Mini-PCI Port Replacement, Port Bracket: Schritt 5, Bild 1 von 1
    • Remove the screw affixing the bracket down.
  6. IBM ThinkPad T42 Mini-PCI Port Replacement, Bracket Removal: Schritt 6, Bild 1 von 1
    • Lift the bracket up and out.
  7. IBM ThinkPad T42 Mini-PCI Port Replacement, Port Removal: Schritt 7, Bild 1 von 1
    • Carefully disconnect it from the motherboard and pull it out of the device.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Gerald Watanabe
279 Reputation
7 Anleitungen geschrieben
Cal Poly, Team 29-76, Johann Spring 2010 Mitglied von Cal Poly, Team 29-76, Johann Spring 2010
CPSU-JOHANN-S10S29G76
4 Mitglieder
35 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 6
Letzten 30 Tage: 11
Insgesamt: 4,277
