Einleitung
This guide shows how to take out and replace the screen in this device.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Locate the screws holding the screen cover in place. There are 3 screws on the left side, 4 on the right, and 4 across the bottom of the screen. There are 3 screws on the left side, 4 on the right, and 4 across the bottom of the screen.
    • Locate the screws holding the screen cover in place.
    • There are 3 screws on the left side, 4 on the right, and 4 across the bottom of the screen.
  2. Remove the covers by inserting plastic spudger in between the edge of the cover and laptop. Remove screws by using the Phillips head #0 The covers are set in with an adhesive so they may pop off when removing them.
    • Remove the covers by inserting plastic spudger in between the edge of the cover and laptop.
    • Remove screws by using the Phillips head #0
    • The covers are set in with an adhesive so they may pop off when removing them.
  3. Insert the flat metal spudger into the edge of the screen cover and slowly pry open. Slide the spudger along the edges and pry open to release the cover from the clips While slide the spudger up the side of the  cover, pinch the cover to help unhook the clips
    • Insert the flat metal spudger into the edge of the screen cover and slowly pry open.
    • Slide the spudger along the edges and pry open to release the cover from the clips
    • While slide the spudger up the side of the cover, pinch the cover to help unhook the clips
    • Across the bottom of the screen there is an adhesive, so you will need to carefully pry of that part of the cover
  4. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  5. Remove the two screws located near the bottom middle of the screen
    • Remove the two screws located near the bottom middle of the screen
  6. Flip over the green rectangular shaped board Disconnect the screen from the rectangular board using your fingers or tweezers Disconnect the screen from the rectangular board using your fingers or tweezers
    • Flip over the green rectangular shaped board
    • Disconnect the screen from the rectangular board using your fingers or tweezers
  7. Using "Flat metal spudger" lift  up the screen from the bottom slowly until you see the ribbon cable
    • Using "Flat metal spudger" lift up the screen from the bottom slowly until you see the ribbon cable
    • Detach the ribbon cable before lifting completely the screen
    • Now you be able to remove the screen
    • Because of how the ribbon cable is connected, it may detach when you lift the screen up
  8. To replace the screen follow the next set of steps Using your fingers or tweezers, pull out the light by placing them on the sides and lifting up Insert the wide plug on the ribbon cable into the new screen and place back into the laptop.
    • To replace the screen follow the next set of steps
    • Using your fingers or tweezers, pull out the light by placing them on the sides and lifting up
    • Insert the wide plug on the ribbon cable into the new screen and place back into the laptop.
    • Now if you follow these steps in reverse order, you will be able to finish replacing the screen
Abschluss
aLiX pIeRRe
786 Reputation
5 Anleitungen geschrieben
UMass Dartmouth, Team S6-G4, Bernier Spring 2018 Mitglied von UMass Dartmouth, Team S6-G4, Bernier Spring 2018
UMASSD-BERNIER-S18S6G4
4 Mitglieder
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 8
Insgesamt: 122
