Einleitung
Replacing or upgrading the RAM for the IBM T43 can give it a greater performance boost.
Was du brauchst
To remove the cover, you will need to take out the single screw.
Unscrew until the cover comes off
Lift the cover from the edge and pull off
Place hands on the RAM and pull towards yourself
For replacement, follow these steps in reverse order
2 weitere Personen haben diese Anleitung absolviert.
Ein Kommentar
There are two (2) SODIM slots on the T43 - this shows the easiest slot to access. There is a second SODIM slot underneath the keyboard. You will need to remove the palm rest and keyboard to access the second SODIM slot. This is the SODIM slot that comes populated with the 512MB SODIM.
Note you can add a 2GB SODIM in one slot with the 512MB SODIM in the other for a maximum of 2.5GB.
