Zum Hauptinhalt wechseln
IBM/Lenovo Thinkpad T61 Hard Drive Replacement
Was du brauchst
  1. IBM/Lenovo Thinkpad T61 Hard Drive Replacement, Hard Drive: Schritt 1, Bild 1 von 1
    • Turn the computer over so that the back is facing upwards.
    • Locate the screw in the bottom left-hand corner of the computer.
  2. IBM/Lenovo Thinkpad T61 Hard Drive Replacement: Schritt 2, Bild 1 von 1
    • Using a #0 Phillips screwdriver, remove the 17 mm screw.
  3. IBM/Lenovo Thinkpad T61 Hard Drive Replacement: Schritt 3, Bild 1 von 1
    • Carefully remove the plastic piece covering the hard drive by first pulling up then away from the computer.
  4. IBM/Lenovo Thinkpad T61 Hard Drive Replacement: Schritt 4, Bild 1 von 2 IBM/Lenovo Thinkpad T61 Hard Drive Replacement: Schritt 4, Bild 2 von 2
    • Locate the folded black tab within the hard drive port.
    • With a screwdriver, pull the black tab out of the slot.
  5. IBM/Lenovo Thinkpad T61 Hard Drive Replacement: Schritt 5, Bild 1 von 2 IBM/Lenovo Thinkpad T61 Hard Drive Replacement: Schritt 5, Bild 2 von 2
    • Pull gently on the black tab and the metal tray holding the hard drive will slide out.
  6. IBM/Lenovo Thinkpad T61 Hard Drive Replacement: Schritt 6, Bild 1 von 1
    • Remove the plastic coverings on both sides of the hard drive.
    • Note that there is no hard drive in this picture but the process will remain the same.
Abschluss
To reassemble your device, follow these instructions in reverse order. If your pull tab is broken, you will need to find something to use as a pull tab for the new drive. You can get a long piece of tape, and fold the end and stick the rest to the drive.
7 weitere Nutzer:innen haben diese Anleitung absolviert.
Kyle
458 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 8-58, Johann Spring 2013 Mitglied von Cal Poly, Team 8-58, Johann Spring 2013
CPSU-JOHANN-S13S8G58
4 Mitglieder
10 Anleitungen geschrieben
Ein Kommentar
Ibm t61 caddy rail purchase
Afjal Ansari - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 12
Letzte 30 Tage: 51
Insgesamt: 6,545
