Einleitung
Use this guide to replace the face buttons of the IFYOO ZD-V108.
The main reasons you would need to replace the face buttons are that the inputs of them are not being read or that they have become stiff, requiring more effort to push them down.
Before proceeding, make sure the device is not plugged in and completely dry, away from any water sources.
Was du brauchst
Remove the seven 9.2 mm screws from the back of the controller using a Phillips #00 screwdriver.
Remove the back cover.
Remove the two 7.2 mm screws that connect the red daughterboard to the tan motherboard using a Phillips #00 screwdriver.
Carefully pull up on the motherboard until it slides off from the four black cylinders keeping it in place.
