Zum Hauptinhalt wechseln
IFYOO ZD-V108 Vibration Motors Replacement
Was du brauchst
  1. IFYOO ZD-V108 Vibration Motors Replacement, Vibration Motors: Schritt 1, Bild 1 von 3 IFYOO ZD-V108 Vibration Motors Replacement, Vibration Motors: Schritt 1, Bild 2 von 3 IFYOO ZD-V108 Vibration Motors Replacement, Vibration Motors: Schritt 1, Bild 3 von 3
    • Remove the seven 9.2 mm screws from the back of the controller using a Phillips #00 screwdriver.
    • Remove the back cover.
    Frag FixBot
    Kommentar hinzufügen
  2. IFYOO ZD-V108 Vibration Motors Replacement: Schritt 2, Bild 1 von 2 IFYOO ZD-V108 Vibration Motors Replacement: Schritt 2, Bild 2 von 2
    • Remove the two 7.2 mm screws that connect the red daughterboard to the tan motherboard using a Phillips #00 screwdriver.
    Frag FixBot
  3. IFYOO ZD-V108 Vibration Motors Replacement: Schritt 3, Bild 1 von 2 IFYOO ZD-V108 Vibration Motors Replacement: Schritt 3, Bild 2 von 2
    • Pull off the glue holding the wires down on both sides of the controller.
    • Pull the vibration motors out of their plastic frames and hold them or set the controller down so as to not strain the wires.
    Frag FixBot
  4. IFYOO ZD-V108 Vibration Motors Replacement: Schritt 4, Bild 1 von 3 IFYOO ZD-V108 Vibration Motors Replacement: Schritt 4, Bild 2 von 3 IFYOO ZD-V108 Vibration Motors Replacement: Schritt 4, Bild 3 von 3
    • Carefully pull up on the motherboard until it slides off from the four black cylinders keeping it in place.
    • Flip the motherboard to its other side and locate the pieces of metal that are connected to the red and black wires.
    Frag FixBot
  5. IFYOO ZD-V108 Vibration Motors Replacement: Schritt 5, Bild 1 von 2 IFYOO ZD-V108 Vibration Motors Replacement: Schritt 5, Bild 2 von 2
    • Use a soldering iron and this soldering guide to desolder both vibration motors’ wires from the motherboard.
    Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Cordell
609 Reputation
5 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 24
Insgesamt: 215
