Einleitung
You may need this guide when you want to vacuum at a close range, such as the stairs. It will instruct you on how to take an attachment off the INSE S6X and replace it with another, and it is written assuming your vacuum is assembled. The attachment in this guide is the cleaner brush head.
Press the metal tube release button with one hand.
Hold the tube with your other hand and pull it out to remove it.
Press the main motor release button with one hand.
Hold the main motor with your other hand and then pull the handle to remove the main motor from the tube.
