Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
In this guide you will learn how to replace the output jack. Output jack replacement will need to be done if your bass no longer makes sound, the bass only makes sound when the cable is orientated awkwardly or the bass cuts in and out when the cable is moved. Your output jack can break because the delicate metal parts which make contact with the instrument cable have been worn out or bent out of shape. Sadly this Ibanez series bass uses a closed output jack, thus it is impossible to fix, and can only be replaced.
  1. Gently place the instrument upside-down on a soft surface.
    • Gently place the instrument upside-down on a soft surface.
    • Locate the battery cavity cap and screws.
  2. Use a phillips head screwdriver to unscrew both screws. Two #1 1mm long screws.
    • Use a phillips head screwdriver to unscrew both screws. Two #1 1mm long screws.
  3. Remove the cap by lifting upwards to reveal the battery. Remove the cap by lifting upwards to reveal the battery.
    • Remove the cap by lifting upwards to reveal the battery.
  4. Gently lift the battery from the cavity. Detach the battery completely by firmly pulling the fabric connector from the conducting end of the battery. Detach the battery completely by firmly pulling the fabric connector from the conducting end of the battery.
    • Gently lift the battery from the cavity.
    • Detach the battery completely by firmly pulling the fabric connector from the conducting end of the battery.
  5. Locate back plate cap and screws.
    • Locate back plate cap and screws.
  6. Use a phillips head screwdriver to remove the four screws,#1-1mm, by turning the screws counter-clockwise. Use a phillips head screwdriver to remove the four screws,#1-1mm, by turning the screws counter-clockwise.
    • Use a phillips head screwdriver to remove the four screws,#1-1mm, by turning the screws counter-clockwise.
  7. Remove cap by lifting upwards, revealing the circuitry of the instrument. Remove cap by lifting upwards, revealing the circuitry of the instrument.
    • Remove cap by lifting upwards, revealing the circuitry of the instrument.
  8. Lift the green printed circuit board to move some of the wires Locate the output jack at the base of the cavity. Move wires away from the end of the output jack to expose the three pins.
    • Lift the green printed circuit board to move some of the wires
    • Locate the output jack at the base of the cavity.
    • Move wires away from the end of the output jack to expose the three pins.
  9. Locate the gold nut at the base of the output Jack. Do not remove the nut completely, but leave it about halfway down the output jack. We only want to move the prongs slightly away from all of the wires to allow for easier soldering.
    • Locate the gold nut at the base of the output Jack.
    • Do not remove the nut completely, but leave it about halfway down the output jack. We only want to move the prongs slightly away from all of the wires to allow for easier soldering.
    • Use the wrench to loosen the nut.
  10. Use a soldering iron to remove the three wires (two black, one white) from the output jack. The soldering iron is extremely hot. Avoid contact with skin, fabric or the body of the instrument. When soldering iron is not in use, rest it on the soldering iron stand. The soldering iron is extremely hot. Avoid contact with skin, fabric or the body of the instrument. When soldering iron is not in use, rest it on the soldering iron stand.
    • Use a soldering iron to remove the three wires (two black, one white) from the output jack.
    • The soldering iron is extremely hot. Avoid contact with skin, fabric or the body of the instrument. When soldering iron is not in use, rest it on the soldering iron stand.
  11. Remove the loosened nut completely by rotating it counter-clockwise. Remove the loosened nut completely by rotating it counter-clockwise. Remove the loosened nut completely by rotating it counter-clockwise.
    • Remove the loosened nut completely by rotating it counter-clockwise.
  12. Flip the bass over. Remove output jack by pushing it gently from the back of the instrument and pulling it out from the front. Insert a new output jack and tighten the nut about halfway.
    • Flip the bass over.
    • Remove output jack by pushing it gently from the back of the instrument and pulling it out from the front.
    • Insert a new output jack and tighten the nut about halfway.
  13. Use the soldering iron to attach the wires on to the new output jack according to the wiring diagram.
    • Use the soldering iron to attach the wires on to the new output jack according to the wiring diagram.
    • Securely tighten the nut using the adjustable wrench.
Abschluss
To reassemble your device, follow steps 1-7 in reverse order.
3 weitere Nutzer haben diese Anleitung absolviert.
Chris Pittner
196 Reputation
7 Anleitungen geschrieben
Cal Poly, Team 5-18, Forte Winter 2013 Mitglied von Cal Poly, Team 5-18, Forte Winter 2013
CPSU-FORTE-W13S5G18
4 Mitglieder
8 Anleitungen geschrieben
Thanks for the good, clear instructions. Well done, very helpful.
m10, Socorro NM
Clifton - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 1
Letzten 7 Tage: 8
Letzten 30 Tage: 57
Insgesamt: 8,207
