Einleitung
The bass guitar is an instrument played all over the world. You can easily identify a bass guitar in music. With normal wear and tear, bass strings should be changed periodically. Bad strings on a bass guitar can change how the music is heard. Changing the strings on a bass guitar is not only easy but also, so much fun!
Was du brauchst
Pull the string through the guitar's bridge and upward though the headstock of the guitar.
After you remove the first string, you will reassemble and continue the process until you have changed all four strings.
