Zum Hauptinhalt wechseln
IdeaPad Yoga 13 Charging Port Replacement
Was du brauchst
  1. IdeaPad Yoga 13 Charging Port Replacement, Charging Port: Schritt 1, Bild 1 von 1
    • Remove all ten screws using the T4 Torx screwdriver.
    • Remove the back cover from the device.
  2. IdeaPad Yoga 13 Charging Port Replacement: Schritt 2, Bild 1 von 2 IdeaPad Yoga 13 Charging Port Replacement: Schritt 2, Bild 2 von 2
    • Use the blue opening tool to further separate the keyboard bezel.
    • Carefully apply pressure to the keyboard. It should easily pop out.
  3. IdeaPad Yoga 13 Charging Port Replacement: Schritt 3, Bild 1 von 1
    • To remove the keyboard bezel, unscrew and remove the five screws using the Phillips #0 screwdriver.
  4. IdeaPad Yoga 13 Charging Port Replacement: Schritt 4, Bild 1 von 2 IdeaPad Yoga 13 Charging Port Replacement: Schritt 4, Bild 2 von 2
    • Unplug the connections from the motherboard.
    • There is a different connection for the mouse and keyboard.
  5. IdeaPad Yoga 13 Charging Port Replacement: Schritt 5, Bild 1 von 1
    • Remove the outer bezel to reveal the entire internal layout of the computer.
    • Motherboard and other internal components are now exposed.
  6. IdeaPad Yoga 13 Charging Port Replacement: Schritt 6, Bild 1 von 3 IdeaPad Yoga 13 Charging Port Replacement: Schritt 6, Bild 2 von 3 IdeaPad Yoga 13 Charging Port Replacement: Schritt 6, Bild 3 von 3
    • Remove charging port by prying out the yellow port from the computer chassis.
    • Note the route of the cable for re-installation of the replacement.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
IUPUI, Team S1-G2, Harley Spring 2019 Mitglied von IUPUI, Team S1-G2, Harley Spring 2019
IUPUI-HARLEY-S19S1G2
3 Mitglieder
2 Anleitungen geschrieben
Ein Kommentar
do you have the schematic of the board?
Jorge Herrera - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 13
Insgesamt: 1,651
