Zum Hauptinhalt wechseln
Identifying Delphi MyFi XM2GO Device Number
Was du brauchst
  1. Identifying Delphi MyFi XM2GO Device Number, Battery Cover: Schritt 1, Bild 1 von 3 Identifying Delphi MyFi XM2GO Device Number, Battery Cover: Schritt 1, Bild 2 von 3 Identifying Delphi MyFi XM2GO Device Number, Battery Cover: Schritt 1, Bild 3 von 3
    • Locate the large button on the top of the device.
    • Push down on the button and slide the cover away from the button.
    • The battery removal tab may pop up.
  2. Identifying Delphi MyFi XM2GO Device Number, Battery: Schritt 2, Bild 1 von 3 Identifying Delphi MyFi XM2GO Device Number, Battery: Schritt 2, Bild 2 von 3 Identifying Delphi MyFi XM2GO Device Number, Battery: Schritt 2, Bild 3 von 3
    • Grab the red pull tab and pull down to unlock the latch.
    • Pull the battery out.
  3. Identifying Delphi MyFi XM2GO Device Number, Identifying Delphi MyFi XM2GO Device Number: Schritt 3, Bild 1 von 1
    • After removing the battery cover and battery, the device information is located near the battery connections highlighted in red.
Abschluss
Scott Byer
61 Reputation
5 Anleitungen geschrieben
Clemson, Team 1-2, Benson Spring 2012 Mitglied von Clemson, Team 1-2, Benson Spring 2012
CLEM-BENSON-S12S1G2
3 Mitglieder
9 Anleitungen geschrieben
Ein Kommentar
What is that pad behind battery ?is ot a thermal pad of some kind?
Torey Mitchell - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 1,477
