Zum Hauptinhalt wechseln
Ikea Hektar Lamp Foot Pedal Switch Button Replacement
Was du brauchst
  1. Ikea Hektar Lamp Foot Pedal Switch Button Replacement, Foot Pedal Lamp Switch Button: Schritt 1, Bild 1 von 2 Ikea Hektar Lamp Foot Pedal Switch Button Replacement, Foot Pedal Lamp Switch Button: Schritt 1, Bild 2 von 2
    • Unplug the lamp from the power source.
    • Do not touch the metal prongs sticking out of the connector, only hold by the plastic section of the chord.
    • Find a well-lit area to work in and begin your repair.
  2. Ikea Hektar Lamp Foot Pedal Switch Button Replacement: Schritt 2, Bild 1 von 3 Ikea Hektar Lamp Foot Pedal Switch Button Replacement: Schritt 2, Bild 2 von 3 Ikea Hektar Lamp Foot Pedal Switch Button Replacement: Schritt 2, Bild 3 von 3
    • Flip the lamp switch upside down.
    • Use a Phillips #0 screwdriver to remove the four 6 mm screws from the bottom of the foot pedal while holding the button cap in place.
  3. Ikea Hektar Lamp Foot Pedal Switch Button Replacement: Schritt 3, Bild 1 von 2 Ikea Hektar Lamp Foot Pedal Switch Button Replacement: Schritt 3, Bild 2 von 2
    • Lift the top off of the foot pedal that holds the button in place and put it to the side.
    • Remove the damaged button from the switch and place it to the side.
  4. Ikea Hektar Lamp Foot Pedal Switch Button Replacement: Schritt 4, Bild 1 von 1
    • Briefly inspect the spring and electrical wiring for any visual damage.
    • If no internal damage is visible, continue to the next step.
  5. Ikea Hektar Lamp Foot Pedal Switch Button Replacement: Schritt 5, Bild 1 von 2 Ikea Hektar Lamp Foot Pedal Switch Button Replacement: Schritt 5, Bild 2 von 2
    • Replace the button and top of the foot pedal.
    • The button must be replaced before the cap to be held in place.
  6. Ikea Hektar Lamp Foot Pedal Switch Button Replacement: Schritt 6, Bild 1 von 3 Ikea Hektar Lamp Foot Pedal Switch Button Replacement: Schritt 6, Bild 2 von 3 Ikea Hektar Lamp Foot Pedal Switch Button Replacement: Schritt 6, Bild 3 von 3
    • Flip the pedal switch upside down.
    • Use a Phillips #0 screwdriver to replace the four 6 mm screws on the back while holding the switch together.
  7. Ikea Hektar Lamp Foot Pedal Switch Button Replacement: Schritt 7, Bild 1 von 2 Ikea Hektar Lamp Foot Pedal Switch Button Replacement: Schritt 7, Bild 2 von 2
    • Inspect the switch for any gaps around the edge.
    • Press down on the button to make sure you hear and/or feel a click.
  8. Ikea Hektar Lamp Foot Pedal Switch Button Replacement: Schritt 8, Bild 1 von 1
    • All done! Now you have a fully functional foot pedal lamp switch.
Abschluss
Jesus Ortiz
157 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 13
Letzte 30 Tage: 38
Insgesamt: 54
