Einleitung
This is a semi-automatic key duplicating machine – meaning operation requires the user to manually engage the carriage while using a lever to pass it along the cutting guide (and cutter). The deburring wheel can be operated by simply engaging (lifting up) the carriage and leaving it in place.
As its name implies, the deburring wheel helps smooth away any burrs, or sharp edges, from a freshly cut key. With frequent usage, this part will need replacing. This guide will demonstrate how to do just that!
Was du brauchst
As you can see, the deburring wheel on this machine is quite worn down. Time to replace!
3 weitere Nutzer:innen haben diese Anleitung absolviert.
