Zum Hauptinhalt wechseln
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
  1. Flip the device over so the bottom is facing up. You will know it is the bottom because there will be six silver screws visible.
    • Flip the device over so the bottom is facing up.
    • You will know it is the bottom because there will be six silver screws visible.
  2. Remove the USB converter device by gently pulling it out. Do not pull the converter device out by the cord.
    • Remove the USB converter device by gently pulling it out.
    • Do not pull the converter device out by the cord.
  3. Remove the six silver screws using a small Phillips head screwdriver. Remove the six silver screws using a small Phillips head screwdriver.
    • Remove the six silver screws using a small Phillips head screwdriver.
  4. MacBook Akku Fix Kits
    Ab $69.99
    Buy Now
    Ab $69.99
    Buy Now
  5. Slide the bottom plastic panel of the shell down so it is free of the end cap and the top panel. Lift panel free of device.
    • Slide the bottom plastic panel of the shell down so it is free of the end cap and the top panel.
    • Lift panel free of device.
  6. Remove the plastic end cap by sliding it forward, freeing from the rest of the device. You can identify the end cap by noting the label "SuperDisk Drive" above where you would insert a floppy disk.
    • Remove the plastic end cap by sliding it forward, freeing from the rest of the device.
    • You can identify the end cap by noting the label "SuperDisk Drive" above where you would insert a floppy disk.
  7. Slide the metal housing out of the plastic shell. Slide the metal housing out of the plastic shell.
    • Slide the metal housing out of the plastic shell.
  8. Slide metal panel out of the metal casing. Slide metal panel out of the metal casing.
    • Slide metal panel out of the metal casing.
  9. Slide disk drive out of metal casing. Slide disk drive out of metal casing.
    • Slide disk drive out of metal casing.
Abschluss
Ryan
1 Reputation
1 Anleitung geschrieben
Ohio State, Team 1-2, Buehl Spring 2014 Mitglied von Ohio State, Team 1-2, Buehl Spring 2014
OSU-BUEHL-S14S1G2
4 Mitglieder
9 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 220
