Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
This guide will show you how to replace the battery in your Impression i7. This guide should be used whenever the battery in your device isn't performing as originally intended by the manufacturer.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Wedge the plastic opening tool into the seam nearest to the screen surface and begin to pry off the back of the device.
    • Wedge the plastic opening tool into the seam nearest to the screen surface and begin to pry off the back of the device.
  2. Move the plastic opening tool along the perimeter of the device, loosening the entire back as you go.
    • Move the plastic opening tool along the perimeter of the device, loosening the entire back as you go.
  3. Nintendo Switch Kits
    Eine schnelle Lösung, um wieder ins Spiel zu kommen
    Switch Kits kaufen
    Switch Kits kaufen
  4. After the entire perimeter has been pried, remove the back of the device.
    • After the entire perimeter has been pried, remove the back of the device.
    • Be careful not to disconnect the speaker and microphone cables attached to the back of the tablet.
  5. Remove the transparent, orange tape from the edge of the battery. Pry the battery off, using the plastic opening tool.
    • Remove the transparent, orange tape from the edge of the battery.
    • Pry the battery off, using the plastic opening tool.
  6. Desolder the positive and negative leads.
    • Desolder the positive and negative leads.
  7. Pull the battery away from the adhesive. Peel the gray tape from the top of the battery.
    • Pull the battery away from the adhesive.
    • Peel the gray tape from the top of the battery.
Abschluss
Cole Beaver
363 Reputation
3 Anleitungen geschrieben
IUPUI, Team S1-G5, Baechle Fall 2018 Mitglied von IUPUI, Team S1-G5, Baechle Fall 2018
IUPUI-BAECHLE-F18S1G5
3 Mitglieder
6 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 3
Insgesamt: 92
