Zum Hauptinhalt wechseln
Impression i7 USB Port Replacement
Was du brauchst
  1. Impression i7 USB Port Replacement, Battery: Schritt 1, Bild 1 von 1
    • Wedge the plastic opening tool into the seam nearest to the screen surface and begin to pry off the back of the device.
  2. Impression i7 USB Port Replacement: Schritt 2, Bild 1 von 1
    • Move the plastic opening tool along the perimeter of the device, loosening the entire back as you go.
  3. Impression i7 USB Port Replacement: Schritt 3, Bild 1 von 1
    • After the entire perimeter has been pried, remove the back of the device.
    • Be careful not to disconnect the speaker and microphone cables attached to the back of the tablet.
  4. Impression i7 USB Port Replacement: Schritt 4, Bild 1 von 2 Impression i7 USB Port Replacement: Schritt 4, Bild 2 von 2
    • Remove the transparent, orange tape from the edge of the battery.
    • Pry the battery off, using the plastic opening tool.
  5. Impression i7 USB Port Replacement: Schritt 5, Bild 1 von 1
    • Desolder the positive and negative leads.
  6. Impression i7 USB Port Replacement: Schritt 6, Bild 1 von 2 Impression i7 USB Port Replacement: Schritt 6, Bild 2 von 2
    • Pull the battery away from the adhesive.
    • Peel the gray tape from the top of the battery.
  7. Impression i7 USB Port Replacement, USB Port: Schritt 7, Bild 1 von 1
    • Remove the five 5 mm screws from the motherboard, using the #0 Phillips Screwdriver.
  8. Impression i7 USB Port Replacement: Schritt 8, Bild 1 von 2 Impression i7 USB Port Replacement: Schritt 8, Bild 2 von 2
    • Using the plastic opening tool tool, pry back the 4 four clips to release the motherboard.
  9. Impression i7 USB Port Replacement: Schritt 9, Bild 1 von 2 Impression i7 USB Port Replacement: Schritt 9, Bild 2 von 2
    • Desolder the eight solder joints holding the USB Port in place.
Abschluss
Cole Beaver
390 Reputation
3 Anleitungen geschrieben
IUPUI, Team S1-G5, Baechle Fall 2018 Mitglied von IUPUI, Team S1-G5, Baechle Fall 2018
IUPUI-BAECHLE-F18S1G5
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 158
