Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
This guide details the necessary steps to replace the USB port on the Impression i7. Due to the difficult nature of this replacement, it should only be performed when all other potential options have been exhausted.
  1. Wedge the plastic opening tool into the seam nearest to the screen surface and begin to pry off the back of the device.
    • Wedge the plastic opening tool into the seam nearest to the screen surface and begin to pry off the back of the device.
  2. Move the plastic opening tool along the perimeter of the device, loosening the entire back as you go.
    • Move the plastic opening tool along the perimeter of the device, loosening the entire back as you go.
  3. After the entire perimeter has been pried, remove the back of the device.
    • After the entire perimeter has been pried, remove the back of the device.
    • Be careful not to disconnect the speaker and microphone cables attached to the back of the tablet.
  4. Essential Electronics Toolkit
    Kompakte Alleskönner.
    Shop Toolkits
    Essential
    Electronics
    Toolkit
    Shop Toolkits
  5. Remove the transparent, orange tape from the edge of the battery. Pry the battery off, using the plastic opening tool.
    • Remove the transparent, orange tape from the edge of the battery.
    • Pry the battery off, using the plastic opening tool.
  6. Desolder the positive and negative leads.
    • Desolder the positive and negative leads.
  7. Pull the battery away from the adhesive. Peel the gray tape from the top of the battery.
    • Pull the battery away from the adhesive.
    • Peel the gray tape from the top of the battery.
  8. Remove the five 5 mm screws from the motherboard, using the #0 Phillips Screwdriver.
    • Remove the five 5 mm screws from the motherboard, using the #0 Phillips Screwdriver.
  9. Using the plastic opening tool tool, pry back the 4 four clips to release the motherboard. Using the plastic opening tool tool, pry back the 4 four clips to release the motherboard.
    • Using the plastic opening tool tool, pry back the 4 four clips to release the motherboard.
  10. Desolder the eight solder joints holding the USB Port in place. Desolder the eight solder joints holding the USB Port in place.
    • Desolder the eight solder joints holding the USB Port in place.
Abschluss
Cole Beaver
363 Reputation
3 Anleitungen geschrieben
IUPUI, Team S1-G5, Baechle Fall 2018 Mitglied von IUPUI, Team S1-G5, Baechle Fall 2018
IUPUI-BAECHLE-F18S1G5
3 Mitglieder
6 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 2
Insgesamt: 61
