Zum Hauptinhalt wechseln
Impressions Vanity Mirror Light Bulb Replacement
Was du brauchst
  1. Impressions Vanity Mirror Light Bulb Replacement, Light Bulb: Schritt 1, Bild 1 von 3 Impressions Vanity Mirror Light Bulb Replacement, Light Bulb: Schritt 1, Bild 2 von 3 Impressions Vanity Mirror Light Bulb Replacement, Light Bulb: Schritt 1, Bild 3 von 3
    • Turn on your mirror to see which light bulb is not working.
  2. Impressions Vanity Mirror Light Bulb Replacement: Schritt 2, Bild 1 von 3 Impressions Vanity Mirror Light Bulb Replacement: Schritt 2, Bild 2 von 3 Impressions Vanity Mirror Light Bulb Replacement: Schritt 2, Bild 3 von 3
    • Now that you know which bulb isn't working, turn off the mirror and disconnect it from the wall outlet to avoid any injuries.
  3. Impressions Vanity Mirror Light Bulb Replacement: Schritt 3, Bild 1 von 2 Impressions Vanity Mirror Light Bulb Replacement: Schritt 3, Bild 2 von 2
    • Turn the light bulb counter clockwise to remove it from the mirror.
  4. Impressions Vanity Mirror Light Bulb Replacement: Schritt 4, Bild 1 von 1
    • Make sure the light bulb that you bought is the same model and wattage as the one you removed.
  5. Impressions Vanity Mirror Light Bulb Replacement: Schritt 5, Bild 1 von 2 Impressions Vanity Mirror Light Bulb Replacement: Schritt 5, Bild 2 von 2
    • Place the new light bulb in its socket and turn it clockwise to secure it.
  6. Impressions Vanity Mirror Light Bulb Replacement: Schritt 6, Bild 1 von 2 Impressions Vanity Mirror Light Bulb Replacement: Schritt 6, Bild 2 von 2
    • Make sure that the bulb is secured in place.
    • If it's not well-secured, the bulb won't light up when the mirror is turned on.
  7. Impressions Vanity Mirror Light Bulb Replacement: Schritt 7, Bild 1 von 1
    • Plug the mirror back into the outlet.
  8. Impressions Vanity Mirror Light Bulb Replacement: Schritt 8, Bild 1 von 3 Impressions Vanity Mirror Light Bulb Replacement: Schritt 8, Bild 2 von 3 Impressions Vanity Mirror Light Bulb Replacement: Schritt 8, Bild 3 von 3
    • Turn on the mirror and check that the new bulb works.
Ziellinie
Yasmin Olivera
157 Reputation
1 Anleitung geschrieben
CSU Los Angeles, Team S1-G80, Harris Spring 2021 Mitglied von CSU Los Angeles, Team S1-G80, Harris Spring 2021
CSULA-HARRIS-S21S1G80
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 44
Insgesamt: 920
