Zum Hauptinhalt wechseln
In-Ear Headphone Control and Mic Block Disassembly
Was du brauchst
  1. In-Ear Headphone Control and Mic Block Disassembly, The Control Unit: Schritt 1, Bild 1 von 1
    • Find the edge of the control unit and get a very fine flathead screw driver (or a plastic pry tool which would do less damage)
  2. In-Ear Headphone Control and Mic Block Disassembly, Opening The Unit: Schritt 2, Bild 1 von 1
    • Wedge the tool in the corner and start sliding it to the left.
    • As you do this slowely twist the screw driver back and forth to release the clips.
    • Try not to let the tool slip into the control unit as this may damage the circuit board inside.
  3. In-Ear Headphone Control and Mic Block Disassembly, Removing The Cover: Schritt 3, Bild 1 von 2 In-Ear Headphone Control and Mic Block Disassembly, Removing The Cover: Schritt 3, Bild 2 von 2
    • Repeat step 2 and the control unit should open as seen in the image.
    • Remove the plastic sleeves and you will be left with just the circuit board (see second image).
  4. In-Ear Headphone Control and Mic Block Disassembly, Identify Broken Wire: Schritt 4, Bild 1 von 1
    • It is quickly seen that one of the wires has broken away from the circuit board (see image)
  5. In-Ear Headphone Control and Mic Block Disassembly, Resolder the Broken Wire: Schritt 5, Bild 1 von 1
    • Once the wire is found a steady hand and a fine tipped soldering iron should be used to reattach the wire.
    • Ensure that you do not head to circuit board for too long as it may cause damage (be as quick as possible!)
    • After this, the circuit board and wires should be replaced as they were before. Press the plastic cover halves together and it should click back into place.
    • And they are fixed!
Abschluss
Your headphones should now be working!
4 weitere Personen haben diese Anleitung absolviert.
Alexander
269 Reputation
1 Anleitung geschrieben
2 Kommentare
Thanks a lot this worked perfectly thank you very much
MD Ratul - Antwort
Very good lesson. Thanks a lot...
PK Chatterjee - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 21
Letzte 30 Tage: 87
Insgesamt: 15,563
